Can i install VCS-C on Hyper-V
I saw only .ova template for software installation.
Can i install VCS-C on Hyper-V instead of Esxi ?
if can, please recommend.
Best Regards,
Chinnapat S.
Jaime Valencia
No, we only support ESXi
java
if this helps, please rate
As Jamie has pointed out, only ESXi is supported, the specs for the virtual VCS can be found below.
Virtualization for Cisco TelePresence Video Communications Server
All,
Thank you so much.
Best Regards,
Chinnapat S.
