Can two SX80's share one Precision 60 camera using a RJ45 A/B switch for camera control?
brandon.lam
Has anyone tested using one Precision 60 camera with two SX80 codecs?  I have a Black Box RJ45 A/B switch for the control switching but it doesn't appear to work.  I tried having only one SX80 powered on at a time.
PJMack
Level 7
Level 7
You'd probably have to power the camera off/on when switching between codecs - the camera gets its IP address from the SX80 when it powers up and then pairs with it. You can't just (with your switch) move the Ethernet connection from one to the other codec, it won't pair on the fly.
