Change Cisco TelePresence PrecisionHD Camera - 720p to SD format
mhmdeldeib
how  to Change Cisco TelePresence PrecisionHD Camera - 720p to SD format.i'm facing problem because of the HD quality so is there  anyway to chaqnge the PrecisionHD Camera - 720p to SD format?
Marius Nedregaard
Hi.
Unfortinatly not,
the only supported configurable resolution for the 720p camera is 1280x720.  480p60 is not yet supported.
Documentation on what the camera is capable of can be found at  http://www.cisco.com/en/US/docs/telepresence/endpoint/camera/precisionhd/user_guide/precisionhd_1080p-720p_camera_user_guide.pdf
/Marius
