multisite license register on sx20
Please you can indicate if the multisite license on sx20 need register on codec?
Thanks for you help
Jca
Magnus Ohm
According to the datasheet multisite is embedded in the sx20.
So i assume you don't have to add this.
/Magnus
Magnus Ohm
/Magnus
Thanks for you answer
I though you needed to add an option key to enable it?
I have a factory fresh, unused SX20 in the office, so I can check tomorrow
Marius Nedregaard
Multisite key should be pre-installed on the codec, but this is not always the case. The multisite option-key is as Magnus stated included in the SX20 bundle, but are NOT guaranteed to be installed on the SX20 prior delivery
/Marius
