Change CUCM SSL Cert attributes
Mike Assel
Level 4
Level 4
How do I change the values of the attributes that CUCM uses to create self-signed certs or CSR's?  I'm referring to the settings that are configured when CUCM is installed, like organization, state, country, etc.
Thanks,  Mike
Jaime Valencia
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/cli_ref/10_0_1/CUCM_BK_CBEED39F_00_cucm-cli-reference-guide-100/CUCM_BK_CBEED39F_00_cucm-cli-reference-guide-100_chapter_0110.html#CUCM_CL_S4787D02_00
java
if this helps, please rate
Jaime Valencia
java
Thank you sir!  Figured it was a CLI operation.  Had a hard time finding it.
Mike
I couldn't find it either.  I was looking under "utils cert".  Would have never found it under "set web-security"  !!!
