Cisco 2811 voice bundle with VWIC2-1MFT-E1
shawvoel
Hi All Expert,
If our PBX system can support PRI interface card, can I used VWIC2-1MFT-E1 as a trunk port which interface with PBX system?
I'm not familiar with VoIP, please advise and thank you.
Rgds,
Au Yeong Shaw Voel
Brandon Buffin
Yes you can. Please see the following link for confirmation.
http://www.cisco.com/en/US/products/hw/routers/ps259/products_data_sheet09186a0080091b9c.html
Hope this helps. If so, please rate the post.
Brandon
Hi Brandon,
Do you know where I can get the configuration guide for this?
Rgds,
Au Yeong Shaw Voel
The configuration will depend on the type of PBX that you have. Take a look at the Interoperability Portal here:
http://www.cisco.com/warp/public/779/largeent/avvid/inter_operability/
Click Enter the Portal, choose Cisco Toll Bypass Products from the dropdown list and then choose your PBX vendor. A list of related documentation will appear in the window below.
Hope this helps.
Brandon
Hi Brandon,
Thank you.
