03-23-2020 12:22 PM
Hi everyone!
I had an old but working immersive system Cisco T3. There were three c90 codecs inside. Is it possible to use one of them as a standalone solution(with dedicated software upgrade) or they work as entire system only? The part number of the codec is CTS-C90CODEC-K9. TTC6-09
Thanks in advance !
03-27-2020 08:17 AM
The answer is yes, but as far as I remember you need a new release key that will also change the product ID once applied. You can try to contact the TAC but I'm not sure they will help...
03-30-2020 09:01 AM
03-30-2020 12:49 PM
Release and option keys survive a factory reset, so it won't help. But you can try to remove the option keys with this API command (better if you have them written somewhere before proceeding):
xcommand systemunit optionkey removeall
Take a look at this post, it explains the difference between standalone C90 and T3's
