Cisco CMS dialing Rules for direct inward dialing
Nishad Ismail
Hi All,
Is there any specific requirement for the TMS & CMS deployment for the DID numbers
Any design criteria we need to take for the CMS deployment in terms of Direct calling to space
We had Cisco CWMS ,now we moving the CMS ,There we had DID single number ,Now in CMS we will have 25 PMP and 2 SMP licenses ,TMS license as well
Anyone can suggest me about the best practice for this deployment
Jaime Valencia
CMS has no requirements for DIDs, you can set it up that way if you want, or you can use the IVR from CMS.
java
if this helps, please rate
This IVR option will apply for Meetings scheduled from the Cisco TMS ?
