CISCO CODEC PRO CANNOT MAKE CALL // 404 SIP NETWORK REJECTED
DAK007
My cisco codec pro is regesteres on my cucm 12.
I'm using the existing SIP trunk base in two differents countries, we can make calls without any problem but now i need to establish telepresence video using the same sip trunk but it fails
Disconnect cause code : 404 SIP
Disconnect cause type : NetworkRejected
can you help
b.winter
Troubleshooting basics: Check the logs (in CUCM, the GW/CUBE, videoendpoint, ...)
