Cisco (Codian) MCU 4510
I have Codian MCU 4510, when i call out to participant , i see SIP display name  "Codian MCU 4510". I can't find how to change display info of MCU. Please help. Any codec has this setting in SIP tab.
Patrick Sparkman
This can't be changed anywhere on the MCU, it's a system default setting and cannot be altered.  See a similar discussion I created here for our MCU 8510.
mcu-8510-sip-display-name
If you use a VCS, you could us CPL to alter the "From" field to properly display what you want, which is what I use to change the source display name.
