Cisco CTS c40 boot problem
maftaba03
Have c40 with T,
No display on any device
Did "factoryreset" via serial port
doesnt accept admin for few minutes
 it accepts any name then "admin: but no password is accepted
after a little while like 5 to 110 minutes it accepts "admin" with no password
but no command line or info available. no display. even typing help not working.
what is the state of system.
Please help us out. Thanks
Thank
Magnus Ohm
The unit is in maintenance mode which means there are issues on the device. In maintenance mode the regular API is not available. It might have crashed on boot and does this every time. So you tried factory reset without luck? (which means that any secondary image has been removed as well)
What software version are you running on this device?
If you have a service contract I advise you to open a case on this to get the instruction on how to restore the system from scratch. You need some special files to do this via the serial port.
/Magnus
Wayne DeNardi
From that screen (in your 2nd screenshot) you could try the selectsw command, and if there are two software images installed, use that to switch to the 2nd installed image - that may boot up, in which case, you should be able to upgrade the endpoint again to replace the possibly corrupt version it's currently booting with.
If there is only one software image installed, you'll need to do as @Magnus suggested, and contact the Cisco TAC (you'll need to have an active service contract on your device) and they should be able to assist.
Wayne
Please
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
