12-19-2012 03:24 AM - edited 03-18-2019 12:19 AM
All
I have a 3511 MCU which isn't booting, I get:
Invalid application on flash. Running Wakeup program
I get a prompt, but I cannot find on documentation on the CLI syntax or if its possible to recover and restore the box.
If anyone can help it would be greatly appreciated as this box is long past it's EoL and support.
12-20-2012 07:10 PM
Hello Andy
What software version of MCU do you have? Did you try upgrade/downgrade it?
There is one thing you can try:
Can you run upgrade utility then use customize option and tick 3 options only (H323 configuration, wake up option, factory default). See if that help.
Thank you
Rafal
12-28-2012 07:33 AM
I can't run the upgrade utility because there's no IP connectivity.
On the console I get the following:
Invalid application on Flash. Running Wakeup program.
ttached TCP/IP interface to motfcc unit 0
Attaching interface lo0...done
Adding 5351 symbols for standalone.
CPU : MPC755
VxWorks Version : 5.5
BSP version : 1.70
Created : Jan 11 2004, 17:43:16
WDB : Ready.
ViaIP MPC755_MPC8260.
BSP version VER_2_0_1REV 1.0
Memory Size: 128 MBytes.
HW Version:0x3
bspSetRoutingTable: Error in routeAdd.
BSP_EXC: Exception hook added
Link is Up, 100M Full Duplex.
Duplex Mode: Manual Full Duplex.
Speed Mode: Manual 100M.
MEMORY OK (address: 0x0 - 0x3000)
Invalid application on Flash. Running the Wakeup program.
So the problem remains I have no documentation on the command line, and is it possible to recover this box.
