Cisco DX70
willicac54
Hi all,
Can someone please advise if there is a way to update the firmware on a DX70 device without using CUCM.
I need to update the unit to version sipdx70.10-2-5-194.
Any information would be greatly appreciated.
Thanks!
Manish Gogna
You may use a third party TFTP , as mentioned in the following link
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/dx/series/rel-notes/1024/DX00_BK_RF53F53D_00_release-notes-dx-series-1024.html#DX00_TK_I35D9F4F_00
Install Firmware ZIP files
If a Cisco Unified Communications Manager is not available to load the installer program, the following .zip files are available to load the firmware.
Firmware upgrades over the WLAN interface may take longer than upgrades that use a wired connection. Upgrade times over the WLAN interface may take more than an hour, depending on the quality and bandwidth of the wireless connection.
Procedure
    Step 1   Go to the following URL: http:/​/​software.cisco.com/​download/​navigator.html.
    Step 2   Choose Collaboration Endpoints > Collaboration Desk Endpoints > Cisco DX Series.
    Step 3   Choose your device type.
    Step 4   In the Latest Releases folder, choose 10.2(4).
    Step 5   Download the relevant zip files.
    • For Cisco DX70: cmterm-dx70.10-2-4-46.zip
    • For Cisco DX80: cmterm-dx80.10-2-4-46.zip
    • For Cisco DX650: cmterm-dx650.10-2-4-46.zip
    Step 6   Unzip the files.
    Step 7   Manually copy the unzipped files to the folder on the TFTP server. See Cisco Unified Communications Operating System Administration Guide for information about how to manually copy the firmware files to the server.
    Thanks, I will give this a try.
    Hi Manish,
    When the device connects to the TFTP server is looking for CTLSEP003094C25D2E.tlvwhere would I find this file.
    Thanks!
