cisco e20... custom phonebook
hi
for some business reason, i must separate phone directory...
can i  use alternative LDAP catalog on e20 ?
Hello Ivan.
I did not see it officially described, but yes you can use scp to transfer the file.
The easiest for you might be to add some entries, download the file, understand the syntax,
change it and upload it again.
The root account has to be enabled on the endpoint. You can find the file under:
/config/pb.xml
You might need to reboot the endpoint after you uploaded the file.
Ivan: please rate my answers using the stars below the messages!
Martin Koch
If you use TMS than sure, you could generate an extra phone book, use the ldap server as the source for it
and set it up just on this endpoint.
Besides that you have the local favorites on the endpoint but thats a local xml file and not a remote live
dlap lookup.
This is whats supported as external phonebooks:
xConfiguration Phonebook Server 1 Type ?
*? xConfiguration Phonebook Server [1..1] Type:
If you need more you should think of filing a featue request.
can i download/upload local xml ?
Hello Ivan.
/config/pb.xml
