Cisco IP 7960 and Cisco Router 2611....
apcgabe
Greetings,
I currently have 2 IP phones and a 2611 series router running 2600-ik902s2-mz.122-15.t5 IOS... Can anyone point me in the right direction on where/or how to start building a mini voice network? Any links, tutorials, info, advice would be greatly appreciated.
Gabe
jtufail
The best thing to setup a mini voip network would be to use the ITS solution where your IP phones will register directly with the 2611 router. The 2611 would act as a mini call manager where these ip phones talk to the router through skinny protocol and your outgoing calls can still go out through your FXO or digital port to the PSTN.
I would suggest to review the following doc. It is fairly complete.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1839/products_feature_guide_book09186a008017fd13.html
If you dont have voice mail, you dont have to worry about that. The above URL is for ITS version 2.1. If you want to run the lates ITS version (3.0) you would need 12.2.15ZJ1 IOS on the router and the information can be found at:
http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/products_feature_guide_book09186a00801812e4.html
Hope that helps.
Thank you for those link, I will be checking those links out later. Thanks again.
