Cisco ISDN Link Gateway
Pooran007
Hi Team,
Hope you are doing good,
I have a doubt between ISDN link & SX20 that according to document(admin guide of isdn link configuration) we need to connect LAN directly ISDN LINK & 2nd port of ISDN link used to SX20 Lan  Now my question is here that why connect to each other can we connect seperate lan for SX20 & ISDN Link & all other configuration will be same. Can we use this seperate LAN Cable.
Pooran
5 Replies 5
Wayne DeNardi
While it may be possible, it won't be a supported solution, so I'd recommend against it. There may be an issue with the automatic pairing to if they're not directly connected to each other.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Hi Wayne,
can i make ISDN pairing by SX20 Remote between SX20 & ISDN Link Gateway because Peripherals option is not coming in advanced setting.
please guide to me...
Pooran
I don't know if you can do it from the Remote - I've always done it (as mentioned in the installation guide) via the web browser interface.
Edit: Make sure you have IPv6 enabled on both the codec and ISDNLink.
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Hi Wayne,
Thanks for your reply..
pairing has been done via the web browser n now i m facing the issue that when i call to any cell number from SX20 then i get the error " codec is not registered with link gateway"
please reply i m waiting..
Pooran
That message is indicating that it's not paried.  Is the web interface showing it is paired, and can you manage the isdnlink via the codec's interface and check that it is actually connected?
Any screenshots of copies of the xconfiguration and xstatus from both the endpoint and the isdnlink will assist us to help you.
Wayne
Wayne
