Cisco meeting server timing disconnection
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
10-31-2018 11:18 AM
Cisco meeting server 2.4.1
SX20 CE9.4.1 and Webex Room Kit CE 9.5
Dial into the CMS using SIP, disconnected every 15 minutes 32 seconds
But using H323 will not be disconnected
Does anyone encounter this situation?
Error message:
2018-11-01 | 01:24:51.825 | Info | call 34573: incoming encrypted SIP call from "sip:192.168.1.202" to local URI "sip:2320@192.168.1.221" |
2018-11-01 | 01:24:51.853 | Info | sending prompt response (2) to BFCP message |
2018-11-01 | 01:24:51.875 | Info | participant "192.168.1.202" joined space c2eb92bd-2585-42ec-9c5c-5fa37ebc7d63 (1.meet) |
2018-11-01 | 01:26:52.263 | Info | call 34574: incoming SIP audio call from "sip:1001@192.168.1.221" to local URI "sip:00348224815826@192.168.1.221" |
2018-11-01 | 01:26:52.273 | Info | call 34574: ending; local teardown, destination URI not matched - not connected after 0:00 |
2018-11-01 | 01:31:55.183 | Info | web user "admin" log in timed out |
2018-11-01 | 01:31:55.183 | Info | web session 1 for user "admin": deactivating due to time out |
2018-11-01 | 01:31:55.183 | Info | web session 1 deactivated for user "admin" |
2018-11-01 | 01:33:20.631 | Info | call 34575: incoming SIP audio call from "sip:1001@192.168.1.221" to local URI "sip:00448224815826@192.168.1.221" |
2018-11-01 | 01:33:20.642 | Info | call 34575: ending; local teardown, destination URI not matched - not connected after 0:00 |
2018-11-01 | 01:34:08.307 | Info | media module status 1 |
2018-11-01 | 01:38:59.979 | Info | call 34576: incoming SIP audio call from "sip:1001@192.168.1.221" to local URI "sip:00548224815826@192.168.1.221" |
2018-11-01 | 01:38:59.988 | Info | call 34576: ending; local teardown, destination URI not matched - not connected after 0:00 |
2018-11-01 | 01:39:51.847 | Info | handshake error 336032784 on outgoing connection 169 to 192.168.1.202:5061 from 192.168.1.221:60148 |
2018-11-01 | 01:40:23.847 | Info | handshake error 336032784 on outgoing connection 170 to 192.168.1.202:5061 from 192.168.1.221:60186 |
2018-11-01 | 01:40:23.847 | Info | call 34573: ending; remote SIP teardown with reason 11 (network - connection closed) - connected for 15:32 |
- Labels:
Conferencing
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-01-2018 08:19 PM
Around the 15 minute mark, usually a SIP Session Refresh is needed, but it seems when the server tries to make the outgoing connection to 192.168.1.202:5061, it doesn't work and it doesn't connect. Perhaps take a pcap from the server and see if the TCP connection is establishing. If not, you may have something blocking it or the endpoint in question is not answering it, or its rejecting it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
05-06-2022 04:05 AM
If not resolved already! When I've seen this issue, it has always been a certificate issue on CMS. When the certificate is signed it should have both client and server extended attributes. In the event it doesn't, the call will get torn down during the SIP refresh. Test by establishing a call not using SIP TLS and see if it remains active for 15 minutes.
