Cisco P60 Camera Color Calibration
Sebastian Frank
we had several speaker track 60 array build into conferencing rooms. However we moved and in the new building they have been replaced by room kits or room systems.
We have a large room where we need several cameras so i thought we rip those ST60 appart and use the P60 cameras alone with an webex codec pro. This works as expected, we can use the cameras and control them via the touchpanel. However if we put the pictures of all cameras on one screen there is a slight color difference between them. I have two pairs of 2 cameras where the color is good within the pair but differs from the other pair. I guess each pair has been one speaker track array.
However I cannot match them with the whitbalance/gamma/brightness setting on the webinterface, even if I point them to a white surface and set it all to auto, the color differs.
is there an option to calibrate them without any external adapters?
0 Replies 0
