07-18-2023 04:32 AM
Need some advice, we are busy updating our clients Telepresence software to the updated version RoomOS 11.1.4.1
We did successfully update over 58 devices to 11.1.4.1 without issues and some had version 9.14.5 on and also 10.19.5.
The issue we are facing is only happening on 7 devices that keeps failing on the installation after the upload. On that had 9.14.5 I first had to update to 10.19.5 k3.cop.sgn before it detects the software of version 11.1.4.1 cop.sha512
But only these devices trying to perform the same steps to update, the only file that worked to get them from 9.14.5 to V10 is 10.15.5.3, but then it still requires 10.19.5 k3.cop/sgn in order to update to V11, but then fails again with same error.
Upgrades being done through device GUI, not understanding why it would fail for these 7 but works for the rest of the devices no issues.
updatesw[1818]: updatesw: detected 'installimage'
updatesw[31521]: [ 0] [* ] Obtaining lock
updatesw[31521]: [ 0] [** ] Determining base directory
updatesw[31521]: [ 0] [*** ] Determining install directory
updatesw[31521]: [ 0] [**** ] Verifying copfile
updatesw[31521]: [ 14] [***** ] Extracting copfile
updatesw[31521]: Failed finding package to install
updatesw[1818]: updatesw: Failed to run installimage
Solved! Go to Solution.
07-21-2023 04:07 AM
Managed to sort out the rest of the devices:
Resolved by skipping 11.1.4.1 and upgraded to 11.5.2.4
I did notice like some sort of bug, image completes upload then shows "Installation failed" then if I click continue it just starts extracting cop file and then installs successfully, even though it says failed.
Hope this helps someone.
07-21-2023 04:07 AM
