Cisco Telepresence - Interoperability of Huawei VC endpoint (third-party)
Chi Fai Leung
I want to make deploy the video servers to operate with Huawei VC endpoints and Cisco VC endpoints to make the functions as below:
1. Point-to-Point video call: VCS
2. Video Conference call: VCS + Conductor + TPS
3. Video Conference Recording: VCS + Conductor + TPS + TCS
I just found the interoperability db about the LifeSize, Microsft, Polycom, RadVision (third-party), but I really cannot find the compatibility on "Huawei" VC endpoint.
Where can I find out the tested compatibility of Huawei VC brand?
5 Replies 5
If you have a look through the Cisco documentation for any of the products and software versions you wish to use you should be able to find the information you are looking for, ie, here's a link to the MCU Series software version 4.5 that includes compatibility information on the Huawei TE30: https://tp-tools-web01.cisco.com/start/d8
Wayne
Please remember to rate responses and to mark your question as answered if appropriate.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
How about the compatibility on VCS?  Huawei vc endpoint would not happen the issue register to VCS calls?
Yes, similar to any standards based third party SIP or H.323 endpoint, if it can be configured correctly, it should be able to register to a Cisco VCS.
Wayne
Wayne
Hi Wayne,
Actually, I tested the Polycom VC endpoint to register to VCS, that can make the point to point call, but fail to make the Content Share on H.239
PolyCom VC-1 (HDX 8000 [software version 3.1.X]) ---(H323 reg. to)----VCS----Conductor-----TPS------PolyCom VC-2 (RealPresence [sofware version 4.1.X] also H323 reg. to the same VCS)
Otherwise, I also tested the point-to-point call from Cisco VC endpoint (SX20) to Huawei VPC600 (Both reg. to VCS) ... but  Huawei side is no sound. Otherwise, if both non-reg. to VCS, point-o-point H323 IP calls from Cisco SX20 to Huawei  VPC600, that is working fine ..........
Edmar Carvalho
Hi Leung,
I had sucess registering Huawei TE30 video conferencing on Cisco VCS and its working properly locally,but know I'm stack on vcs search rules to make this EP able to make and receive video calls from outside.
