Cisco TelePresence ISDN Link 802.1X Compatible?
Is the Cisco TelePresence ISDN Link 802.1X Compatible?
Model: FTT171201BP
Software: TC7.3.3.c84180a
Anurag Srivastava1
You can refer the datasheets of ISDN link-
https://www.cisco.com/c/dam/en/us/products/collateral/collaboration-endpoints/telepresence-isdn-link/telepresence_isdn_link.pdf
It will give an idea with which you can use it
Please rate if it is helpful and mark as accepted solution if applicable...
Please rate if it is helpful and mark as accepted solution if applicable....
