Cisco TMS Synchronize TMS Users with AD Problem
ailhan001
I am using Cisco TMS 15.6.1 on Windows Server 2012 R2.
I entered AD information in TMS and checked successfully.
But,
When i try to sync tms user with AD Problem, it stays 0% Pending situation.
Is there any solution about it?
Best Regards.
Patrick Sparkman
Can you provide more information, possibly provide screenshots, your issue is pretty vague without knowing more.
Where are you trying to sync the AD user?
  1. Admin Tools > User Administration > Groups
  2. Admin Tools > User Administration > Users
Is it just this single user that has the issue, or are there others?
Zac Colton
It sounds like the TMSSchedulerService is not kicking off the task. You should look into that service (ensure that it is running, check the logs for the service)
