CISCO TMS with Webex Integration
Mubarak ali Ali
Dears ,
We are Planing to integrate CISCO Video Conferencing Network with the CISCO web-ex , Please advice below server will support for the Integration /
we have
  • Cisco MCU - Cisco TelePresence MCU 4501
  • CISCO VCS - Cisco Telepresence Video Communication Server Control - Software Version(X7.2.2)
  • Cisco VCSE - Cisco Telepresence Video Communication Server Express way - Software Version (X7.2.2)
Thanks.,
Patrick Sparkman
Hello Mubarak -
It believe they are all supported, I know the VCS's are.  When you start the WebEx integration, you'll need to go through an A2Q process with a Cisco certified partner and they'll help make sure all aspects of your environment meets the requirements.
