Cisco TMSPE key_value error error when installing
Daniel Isham
Level 4
Level 4
We are receiving an error when installing Cisco TMSPE 1.1, which is a brand new installation. We are getting a key_value invalid error when trying to continue after entering in the SQL credential information. We have checked the SQL server and verified proper permissions. We have followed the TMSPE install guide exactly.
What does the key_value indicate in relation to SQL and TMSPE? Is this strictly an issue with SQL?
6 Replies 6
Daniel Isham
Level 4
Level 4
The exact error displayed is "Invalid object name key_value"
Hi Daniel, you are most likely hitting that bug:
https://tools.cisco.com/bugsearch/bug/CSCug74973
Excellent, thank you very much for shedding light on the bug. We followed the instructions provided and was able to install TMSPE.
Thanks Thomas, we had the same error code today. We opted to install tmspe 1.0 first which then allowed us to install tmspe 1.1
Thanks for the information.
Hi Daniel, I concur with Thomas. Try the workaround as mentioned in the BUG details and let us know.
BR, Mahesh Adithiyha
Hi Daniel, Thank you for sharing the update and to know it is working fine now.
