Cisco TX 9000 support second camera.
Arbenjamin
Dear all,
Our client would like to add a second camera in TX9000, is it possible to have such design?
We are planning to connect the second camera with the HDMI and daisy chain control cable to centre C90 video codec, also, there will be a extra power supply for the second camera.
Anyone has such experience or not.
Best Regards,
Ben
Marius Nedregaard
Hi.
This is possible by using the document camera feature to have an extra camera to be connected to the system.
Please note that TX9000 does not use C90 codec, nor cameras with video control - and it does not support camera control.
//Marius
Marius Nedregaard
Hi.
//Marius
Dear Marius
Thank for your kindly support.
By the way, if there any limitation in install the doc camera for the TX9000.
Best Regards,
Ben
