02-22-2016 04:49 AM - last edited on 03-25-2019 09:15 PM by ciscomoderator
Hi Team,
I am going to configured the VCS-C and VCS- E with 5320 MCU.
My question is i was going through with cisco document of VSC-C and E for the configuration.
I think i can do the configuration of VCS-C and E but how to integrate with the Cisco MCU 5320 and how does the calling will be done.
With in same network we can dial Alias number but how about the outside network endpoint will participate in MCU.
I have doubt about the dialing system and if Multiparty call will there than on which URI or Alias will be dialed a call.
For reference :
1) Cisco TelePresence 5320 MCU of 40 ports
2) Cisco C220 M3 server with VCS-C and VCS-E application.
If any one having this topology document please share.
Laxminarayan
Solved! Go to Solution.
02-22-2016 07:39 AM
Hi Laxminarayan,
In the two guides below you will find the steps needed to configure the MCU and the VCS, including Dial Plan/Search Rules.
(p.18 - Deploying an MCU registered to Cisco VCS)
(VCS MCU Deployment using H.323)
02-22-2016 07:39 AM
Hi Laxminarayan,
02-22-2016 08:14 AM
Refer to the MCU 45X0, 53X0 and MCU MSE 8510 Version 4.5 Deployment Guide on how to configure your MCU to work with your VCS. The MCU will register itself to your VCS-C as well as any conference that is running on it, then any endpoints registered to either your VCS-C or E can simply call the conference H323 or SIP address that the MCU has registered to your VCS with, the same can be done by external endpoints not within your organization as well.
