No, you cannot since the factory reset via an unprotected Touch 10 is done as administrator. I recommend you to lock down the settings to prevent users from doing factory reset, by default these settings are available to anyone.
To challenge users trying to do a factory reset of the device you need to set a strong admin password on the device and set the configuration as follows:
xConfiguration UserInterface SettingsMenu Mode: Locked
If you want to hide IP information etc in the UI you can in addition apply this command:
xConfiguration UserInterface Security Mode: Strong
If you are provisioned via CUCM its better to bulk provisioning these settings to apply to all managed devices.
There is also a risk of the user doing a pin-hole factory reset though but its a bit trickier to perform.
/Magnus
