10-15-2020 04:46 AM
How to add the Cisco Webex room Kit Plus on the TMS System to join on telepresence meetings.
Please suggest!!
Solved! Go to Solution.
10-21-2020 08:52 PM
If your Webex Room Kit Plus is registered to your on-prem video environment, then you would add it as you would add any other model of on-prem device.
If it is registered to the Webex Cloud, then you would need to add it as an Unmanaged Endpoint as it cannot be managed by TMS.
Please remember to mark helpful responses and to set your question as answered if appropriate.
10-21-2020 08:52 PM
