Hello world,
I recently wanted to deploy LSC-Certificates on some SX20 systems and WebEx Room Kits. For the authentication method I used "precedence to MIC" since I assumed that every Cisco endpoint ships with a MIC from Cisco. I couldn't get it to work so I went ahead and "tried" to extract the certificate from the system. Neither worked cli nor gui. As it turns out all the SX20s and WebEx Room Kits don't have a MIC installed. Is that a known issue?
Now I am left with the "null string" option to provision the endpoints with LSCs.
Thank you in advance.
