CMR Hybrid : Configuring WebEx Users in Cisco TMS
Bryan Wulfric
Hi all,
I'm using TMS version 14.6. I'm trying to configure CMR Hybrid user in TMS. When i enter Webex username & password then i click Save, it shows error message : "Cannot connect to the WebEx site". I'm sure that webex site,webex username, and webex password is correct cause i can login using web browser to webex site URL.
Does anybody have any idea?
Thanks.
Patrick Sparkman
Has your WebEx site been provisioned to support CMR Hyrbid?
CMR Hyrbid requires a Cisco partner to perform the installation, this is outlined in the "Ordering and Deploying CMR Hybrid" section of the CMR Hyrbid Release Notes for TMS 14.6.
Hi Patrick,
Thank you for your info.
