CMS 2.4.2 WebRTC and Microsoft Edge via Expressway - anyone got it working?
CMS 2.4.2 introduces WebRTC compatibility with Microsoft Edge.  I've upgraded a CMS to this version and it seems to work OK joining on-network, but I can't get it to work via Expressway - when I try and join a meeting, the Windows PC goes black for for a bit, then it goes to the spinning circle before going back to the login page.  This is similar to what I see when the TURN server isn't working, however in this case it works fine from Chrome and Firefox from the same Windows PC which would indicate that both TURN and network connectivity are fine.
Any ideas?  Is Microsoft Edge even supported over Expressway?
EDIT:  The release notes were later changed to specifically exclude Expressway compatibility.
Todd Hebert
Level 5
Level 5
CMS 2.6.1 and Expressway 8.11.4, I need to do more testing, but initial testing with screen-sharing looks pretty good for Microsoft Edge on these versions.
