cms api failed
ahmed
hi all,
i have installed cms 2.2.9 and running well now, i want to add some api command using postman.
but when i posting, i got error message invalid operatio (attached).
i just copy paste from API guide, and re spell again but still problem.
my steps was :
1. open https://cms ip:445/api/v1/system/profiles, then copy the callLegs ID
2. then tried GET from those callLegs ID and OK,i can see many keys and value on it
3. tried POST using same callLegs ID, but failed to post
2 Accepted Solutions
Dennis Fogler
Ahmed,
   Try using PUT versus POST.   -Dennis
Patrick Sparkman
You're modifying an existing callLeg, so you need to use PUT, instead of POST.
For reference, here are the supported API commands and which one to use when:
  • GET is used for retrieval of existing information.
  • POST is used to create new objects.
  • PUT is used to modify an existing object.
  • DELETE is used to destroy an object in the tree.
Dennis Fogler
Ahmed,
Patrick Sparkman
