CMS booting problem
ibnoesany28
Hii...
I have a cms server and it works well before. Some time ago there was a problem with the server when booting & the error message "no mapping found". Any body can help to solve this issue? Thanks
Jaime Valencia
I'd suggest you open up a TAC to have that looked at, worst case scenario you'll have to re-install, hopefully you have a backup from your server.
java
if this helps, please rate
Jaime Valencia
java
Hii Jaime,
Thanks for your feedback
