CMS Edge IPv6 compatibility
Good afternoon,
We are trying to access our CMS Edge via VPN that works in IPv6. I have not found info regarding the compatibility between CMS and the possibility of working with IPv4 and IPv6.
Could you help?
Juan
abcdedghi1
Hey Juan
I found this document below which seems to say:
"When you transition from a traditional IPv4 network to an IPv6 dual-stack network deployment, the following functionality is not supported and is not tested :
      - Cisco meeting Server"
Scroll down to the topic in the document below that says "CSR 12.1/12.0 Deployment Gaps".  Hope this helps.
https://www.cisco.com/c/en/us/support/conferencing/meeting-server/tsd-products-support-series-home.html
