11-23-2018 02:31 AM - edited 11-23-2018 02:32 AM
Hello, everybody.
Could someone help in configuring Dial Transforms, please ?
This is CMS 2.4 and SIP integration with Exp-C.
I am configuring Dial Transforms for simplicity of dialing from CMM.
For example, dialing 5XXX@domain.ru line is working fine.
In addition to this, because of this rule
Raw | ($1/^5...$/) | $1@domain.ru |
I don't need to dial the domain portion as well, but only 5XXX.
Dialing format IP@domain.ru is working also.
The goal is to configure Dial Transforms to dial only IP address, XXX.XXX.XXX.XXX and CMS would append @domain.ru automatically. The rule like this doesn't work so far.
Raw | ($1/^(.*)\.(.*)\.(.*)\.(.*)$/) | $1@domain.ru |
03-04-2019 01:04 AM
Guys, anyone ?
03-05-2019 03:50 AM
Call routing on CMS based on domains, so you have to keep domain in URI on CMS and cut it on Expressway then.
Please read how to do it on Expressway, you need to convert URI IP@domain into IP on Expressway (skip cucm configuration):
