CMS - Select layout for recording
Carlos Sanz
Level 5
Level 5
Hello:
I I'm reviewing the CMS Meeting Server (API Reference Guide) and I can't find out how to change the recording layout, someone knows how to change the recording layout.
5 Replies 5
Anurag Srivastava1
Hello
Can you please explain more what exactly you wanted to achieve and what you are trying through APIs?
Please rate if it is helpful and mark as accepted solution if applicable....
Hello:
In a meeting with recording enabled, participants can change the layout, but I can't change the layout of the recording so that it only records the main stream and don't all assistant, because we need only the main stream. Thanks
Carlos Sanz
Resolved in CMS version 3
Could you please share, how?
My guess is how to change the layout for recording.
In the meeting with recording enabled, participants are seeing onePlusN video but the recorder is getting overlay video or something.
Expecting I have same question as you but correct me if I am wrong, Carlos.
