Codec Plus - Change display mode based on active participant
a.roberto
Good morning we are trying to change the behavior of the Cisco codec model Cisco Spark Codec Plus.
Basically we need the codec to follow the voice based on where it comes from, for example if remote participant speaks - we need to see only that participant (this already works), but when audio comes from the codec itself I would like to see the camera connected to the codec (always in fullscreen - and this we can't do).
I saw in xAPI that you can detect the active participant if you work with api on premises, but unfortunately we work in cloud.
Thanks for your help
0 Replies 0
