Codec Reboots
ccarnuccio
We have thirty plus SX20s, SX80s, C40s and EX90s; they run 24/7, should they be rebooted/restarted after running so many days?
Randy Valverde Rojas
Recommendation is to reboot them about around every 3 months at least, but as stated above, the endpoints are very stable most of the times and can run for much longer.
PJMack
Level 7
Level 7
No, you can leave them alone unless you are having a problem. I've seen endpoints online for over a year, although you should generally update your software more frequently than that.
