Codec SX80 gets stuck on booting. Has anybody experienced something similar ?
proziumwtf
We've got a used Cisco Codec SX80 ( TTC6-12 ). The device seems pretty unresponsive when connected to a monitor and also the uplink doesn't get up. On the console port however there is some ouput :
(0,0) Tilera Hypervisor, version 4.3.3.184581 (source dist) 2017-06-16 11:28:27
(0,0) BiB override from 'CiscoBibEntry_2_E_0'
(0,0) Built by henribak from /home/henribak/src/tc-branch-os/product/carbon/initramfs/_build/v2/root/boot/carbon.hvc, /home/henribak/src/tc-branch-os/product/carbon/initramfs/_build/v2/root/boot with RELEASE=144 MEMPROF XARGS+=TLR_ROOT=none XARGS+=TLR_ROOT_OPTIONS=rw XARGS+=hugepagesz=64M XARGS+=hugepages=5 XARGS+=tile_net.cpus=0-1 XARGS+=pci_gx.msi_cpu_offset=2 XARGS+=skew_tick=1 XARGS+=rcu_nocbs=2,3,7-35, release=144
Initializing cgroup subsys cpuset
Initializing cgroup subsys cpuacct
Linux version 3.10.104-144 (henribak@rdbuild17) (gcc version 4.8.2 (crosstool-NG crosstool-ng-1.22.0-93-g38b3a06) ) #1 SMP PREEMPT Fri Jun 16 10:16:35 CEST 2017
4048MB memory available.
PERCPU: 2 64K pages/cpu @fffffff600000000 s83584 r8192 d39296
Built 2 zonelists in Node order, mobility grouping on.  Total pages: 64704
Policy zone: Normal
Kernel command line: TLR_NETWORK=auto  TLR_ROOT=none TLR_ROOT_OPTIONS=rw hugepagesz=64M hugepages=5 tile_net.cpus=0-1 pci_gx.msi_cpu_offset=2 skew_tick=1 rcu_nocbs=2,3,7-35
PID hash table entries: 4096 (order: -1, 32768 bytes)
Sorting __ex_table...
Memory: 3697216k/4145152k available (9113k kernel code, 4183k data, 696k init, 0k highmem)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=36, Nodes=4
Preemptible hierarchical RCU implementation.
        Experimental no-CBs CPUs: 2-3,7-35.
NR_IRQS:256
console [hvc0] enabled
Clock rate yields 2400.00 BogoMIPS (lpj=12000000)
pid_max: default: 36864 minimum: 301
Dentry cache hash table entries: 524288 (order: 6, 4194304 bytes)
Inode-cache hash table entries: 262144 (order: 5, 2097152 bytes)
Mount-cache hash table entries: 4096
Initializing cgroup subsys debug
Initializing cgroup subsys devices
Initializing cgroup subsys net_cls
Initializing cgroup subsys blkio
ftrace: allocating 19431 entries in 5 pages
Brought up 36 CPUs
devtmpfs: initialized
NET: Registered protocol family 16
I2C-0: Number of configured devices: 27
I2C-1: Number of configured devices: 21
I2C-2: Number of configured devices: 18
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
media: Linux media interface: v0.10
Linux video capture interface: v2.00
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
Switching to clocksource cycle counter
NET: Registered protocol family 2
TCP established hash table entries: 32768 (order: 3, 524288 bytes)
TCP bind hash table entries: 32768 (order: 3, 524288 bytes)
TCP: Hash tables configured (established 32768 bind 32768)
TCP: reno registered
UDP hash table entries: 2048 (order: 0, 65536 bytes)
UDP-Lite hash table entries: 2048 (order: 0, 65536 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
Trying to unpack rootfs image as initramfs...
futex hash table entries: 16384 (order: 4, 1048576 bytes)
audit: initializing netlink socket (disabled)
type=2000 audit(1.829:1): initialized
HugeTLB registered 64 MB page size, pre-allocated 5 pages
HugeTLB registered 16 MB page size, pre-allocated 0 pages
squashfs: version 4.0 (2009/01/31) Phillip Lougher
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
fuse init (API version 7.22)
msgmni has been set to 7920
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
io scheduler noop registered
io scheduler deadline registered
io scheduler cfq registered (default)
Tilera RNG not detected
brd: module loaded
loop: module loaded
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
sky2: driver version 1.30
Tilera Network Driver
Linux network CPUs: 0-1
Fusion MPT base driver 3.04.20
Copyright (c) 1999-2008 LSI Corporation
Fusion MPT SAS Host driver 3.04.20
ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
tilegx-ehci tilegx-ehci.0: Tile-Gx EHCI
tilegx-ehci tilegx-ehci.0: new USB bus registered, assigned bus number 1
tilegx-ehci tilegx-ehci.0: irq 2, io mem 0xfffffff600fe0000
tilegx-ehci tilegx-ehci.0: USB 0.0 started, EHCI 1.00
usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb1: Product: Tile-Gx EHCI
usb usb1: Manufacturer: Linux 3.10.104-144 ehci_hcd
usb usb1: SerialNumber: tilegx-ehci.0
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
tilegx-ehci tilegx-ehci.1: Tile-Gx EHCI
tilegx-ehci tilegx-ehci.1: new USB bus registered, assigned bus number 2
tilegx-ehci tilegx-ehci.1: irq 3, io mem 0xfffffff605360000
tilegx-ehci tilegx-ehci.1: USB 0.0 started, EHCI 1.00
usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
usb usb2: Product: Tile-Gx EHCI
usb usb2: Manufacturer: Linux 3.10.104-144 ehci_hcd
usb usb2: SerialNumber: tilegx-ehci.1
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 1 port detected
ehci-pci: EHCI PCI platform driver
usbcore: registered new interface driver usb-storage
usbcore: registered new interface driver usbserial
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial support registered for generic
usbcore: registered new interface driver aircable
usbserial: USB Serial support registered for aircable
usbcore: registered new interface driver ark3116
usbserial: USB Serial support registered for ark3116
usbcore: registered new interface driver belkin_sa
usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
usbcore: registered new interface driver ch341
usbserial: USB Serial support registered for ch341-uart
usbcore: registered new interface driver cp210x
usbserial: USB Serial support registered for cp210x
usbcore: registered new interface driver cypress_m8
usbserial: USB Serial support registered for DeLorme Earthmate USB
usbserial: USB Serial support registered for HID->COM RS232 Adapter
usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
usbcore: registered new interface driver usb_debug
usbserial: USB Serial support registered for debug
usbcore: registered new interface driver digi_acceleport
usbserial: USB Serial support registered for Digi 2 port USB adapter
usbserial: USB Serial support registered for Digi 4 port USB adapter
usbcore: registered new interface driver io_edgeport
usbserial: USB Serial support registered for Edgeport 2 port adapter
usbserial: USB Serial support registered for Edgeport 4 port adapter
usbserial: USB Serial support registered for Edgeport 8 port adapter
usbserial: USB Serial support registered for EPiC device
usbcore: registered new interface driver io_ti
usbserial: USB Serial support registered for Edgeport TI 1 port adapter
usbserial: USB Serial support registered for Edgeport TI 2 port adapter
usbcore: registered new interface driver empeg
usbserial: USB Serial support registered for empeg
usbcore: registered new interface driver f81232
usbserial: USB Serial support registered for f81232
usbcore: registered new interface driver ftdi_sio
usbserial: USB Serial support registered for FTDI USB Serial Device
usbcore: registered new interface driver funsoft
usbserial: USB Serial support registered for funsoft
usbcore: registered new interface driver ir_usb
usbserial: USB Serial support registered for IR Dongle
usbcore: registered new interface driver keyspan
usbserial: USB Serial support registered for Keyspan - (without firmware)
usbserial: USB Serial support registered for Keyspan 1 port adapter
usbserial: USB Serial support registered for Keyspan 2 port adapter
usbserial: USB Serial support registered for Keyspan 4 port adapter
usbcore: registered new interface driver mct_u232
usbserial: USB Serial support registered for MCT U232
usbcore: registered new interface driver mos7720
usbserial: USB Serial support registered for Moschip 2 port adapter
usbcore: registered new interface driver mos7840
usbserial: USB Serial support registered for Moschip 7840/7820 USB Serial Driver
usbcore: registered new interface driver oti6858
usbserial: USB Serial support registered for oti6858
usbcore: registered new interface driver pl2303
usbserial: USB Serial support registered for pl2303
usbcore: registered new interface driver qcaux
usbserial: USB Serial support registered for qcaux
usbcore: registered new interface driver qcserial
usbserial: USB Serial support registered for Qualcomm USB modem
usbcore: registered new interface driver safe_serial
usbserial: USB Serial support registered for safe_serial
usbcore: registered new interface driver siemens_mpi
usbserial: USB Serial support registered for siemens_mpi
usbcore: registered new interface driver sierra
usbserial: USB Serial support registered for Sierra USB modem
usbcore: registered new interface driver spcp8x5
usbserial: USB Serial support registered for SPCP8x5
usbcore: registered new interface driver ssu100
usbserial: USB Serial support registered for Quatech SSU-100 USB to Serial Driver
usbcore: registered new interface driver keyspan_pda
usbserial: USB Serial support registered for Keyspan PDA
usbserial: USB Serial support registered for Xircom / Entregra PGS - (prerenumeration)
usbcore: registered new interface driver vivopay_serial
usbserial: USB Serial support registered for vivopay-serial
i2c /dev entries driver
at24 0-0050: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
at24 0-0051: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
rtc-ds1307 0-0068: rtc core: registered m41t00 as rtc0
at24 1-0050: 65536 byte 24c512 EEPROM, writable, 1 bytes/write
device-mapper: uevent: version 1.0.3
device-mapper: ioctl: 4.24.0-ioctl (2013-01-15) initialised: dm-devel@redhat.com
EDAC MC0: Giving out device to 'tile-edac' 'TILEGx_Memory_Controller': DEV tile-edac.0
EDAC MC1: Giving out device to 'tile-edac' 'TILEGx_Memory_Controller': DEV tile-edac.1
ip_tables: (C) 2000-2006 Netfilter Core Team
NET: Registered protocol family 10
NET: Registered protocol family 17
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
registered taskstats version 1
rtc-ds1307 0-0068: setting system clock to 2000-01-01 00:08:30 UTC (946685310)
ALSA device list:
  No soundcards found.
^[^[^[^[^[^C^C^C^C^]^]^]^]^[[^]^]^C^C^C^C^C  ^[^[^[^[^[^[Freeing unused kernel data: 384k freed
Freeing unused kernel text: 320k freed
Waiting up to 10 seconds for /dev/sda1
usb 1-1: new high-speed USB device number 2 using tilegx-ehci
usb 1-1: New USB device found, idVendor=0424, idProduct=2512
usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
hub 1-1:1.0: USB hub found
hub 1-1:1.0: 2 ports detected
usb 2-1: new high-speed USB device number 2 using tilegx-ehci
usb 2-1: New USB device found, idVendor=0424, idProduct=2240
usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 2-1: Product: Ultra Fast Media
usb 2-1: Manufacturer: Generic
usb 2-1: SerialNumber: 000000225001
usb-storage 2-1:1.0: USB Mass Storage device detected
scsi0 : usb-storage 2-1:1.0
scsi 0:0:0:0: Direct-Access     Generic  Ultra HS-COMBO   1.98 PQ: 0 ANSI: 0
sd 0:0:0:0: [sda] 15269888 512-byte logical blocks: (7.81 GB/7.28 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] No Caching mode page found
sd 0:0:0:0: [sda] Assuming drive cache: write through
 sda: sda1
sd 0:0:0:0: [sda] Attached SCSI removable disk
Checking file system
fsck 1.42.13 (17-May-2015)
e2fsck 1.42.13 (17-May-2015)
/dev/sda1: recovering journal
/dev/sda1: clean, 87/477664 files, 256375/1906960 blocks
Mounting flash disk
EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Enter boot option(f: factory reset)
Loopback-mounting root
Bind-mounting flash disk
Switching root
^C/init: line 3: /bin/mount: Input/output error
/init: line 4: /bin/mount: Input/output error
/init: line 5: /bin/mount: Input/output error
/init: line 6: /bin/mount: Input/output error
/init: line 7: /bin/mount: Input/output error
ln: /var/run/run: Read-only file system
cat: can't open '/sys/hypervisor/board/board_part': No such file or directory
cat: can't open '/sys/hypervisor/board/board_revision': No such file or directory
mkdir: can't create directory '/tmp/hwconfig': Read-only file system
/bin/hwconfig: line 26: /tmp/hwconfig/product: No such file or directory
/bin/hwconfig: line 27: /tmp/hwconfig/pcb: No such file or directory
/bin/hwconfig: line 28: /tmp/hwconfig/ver: No such file or directory
/bin/hwconfig: line 29: /tmp/hwconfig/productinfo.env: No such file or directory
/bin/hwconfig: line 34: /tmp/hwconfig/msno: No such file or directory
/bin/hwconfig: line 37: /tmp/hwconfig/hw-level: No such file or directory
[//etc/systemd/system.conf:22] Unknown lvalue 'DefaultControllers' in section 'Manager'
/lib/systemd/system-generators/device-hugepages: line 6: /bin/mount: Input/output error
/lib/systemd/system-generators/key-generator: line 3: /bin/disksetup: Input/output error
/lib/systemd/system-generators/device-hugepages: line 36: /bin/mount: Input/output error
mknod: /dev/iorpc/gpio0: File exists
And this is pretty much all I get. Is it dead ? Is there a way to try and fix it ? I've tried looking for a procedure to deal with a corrupted image, but didn't find anything online.
Any ideas?
Thanks!
Alex
Looks very much like the internal file system is damaged.  Your easiest option would be to log an RMA with the Cisco TAC.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
Thank you, I've thought so too. This would be the easiest option, but since the contract for this device is long gone, it's not supported by TAC. Is there a way to try and rescue it myself ? Is there any way that I could reimage it or the procedure is not that easy and not documented ?
123qwer
Had the same problem today. But after filesystem check SX80 had rebooting in a loop.
Tryed to access the CLI via serial (115200, N, 8, 1) with follows:
<---skip--->
fsck 1.42.10 (18-May-2014)
e2fsck 1.42.10 (18-May-2014)
/dev/sda1: clean, 46/477664 files, 159314/1906960 blocks (check after next mount)
Mounting flash disk
Switching root
systemd-fsck[711]: /dev/mapper/uifs: recovering journal
systemd-fsck[700]: /dev/mapper/config: recovering journal
systemd-fsck[711]: /dev/mapper/uifs: clean, 11/3584 files, 1605/14336 blocks
systemd-fsck[700]: /dev/mapper/config: clean, 22/7680 files, 2398/30720 blocks
(0,0) Tilera Hypervisor, version 4.2.4.174600 (source dist) 2015-02-26 23:11:12
(0,0) Built by henribak from /home/henribak/src/tc-branch-os/make/carbon/initramfs/_build/root/boot/carbon.hvc, ../initramfs/_build/root/boot with RELEASE=93 MEMPROF XARGS+=TLR_ROOT=none XARGS+=TLR_ROOT_OPTIONS=rw XARGS+=hugepagesz=64M XARGS+=hugepages=5 XARGS+=tile_net.cpus=0-1 XARGS+=pci_gx.msi_cpu_offset=2 XARGS+=skew_tick=1, release=93
(0,0) Warning: Could not find mode!
<---skip--->
Then the system was rebooted again and again an infinite number of times
After cold start I pressed  power button twice for factory reset. (Like in this video  )
hecking file system
Mounting flash disk
Switching root
systemd-fsck[718]: /dev/mapper/config: recovering journal
systemd-fsck[728]: /dev/mapper/uifs: recovering journal
systemd-fsck[718]: /dev/mapper/config: clean, 21/7680 files, 2395/30720 blocks
systemd-fsck[728]: /dev/mapper/uifs: clean, 11/3584 files, 1605/14336 blocks
Hardware-triggered factory reset being performed
Shutting down
Unmounted /oldroot/run
Unmounted /oldroot/proc
Unmounted /oldroot/dev/shm
Unmounted /oldroot/dev/pts
Unmounted /oldroot/sys/fs/cgroup/systemd
Unmounted /oldroot/sys/fs/cgroup/cpuset
Unmounted /oldroot/sys/fs/cgroup/debug
Unmounted /oldroot/sys/fs/cgroup/cpu,cpuacct
Unmounted /oldroot/sys/fs/cgroup/memory
Unmounted /oldroot/sys/fs/cgroup/devices
Unmounted /oldroot/sys/fs/cgroup/net_cls
Unmounted /oldroot/sys/fs/cgroup/blkio
Unmounted /oldroot
losetup: /dev/loop0: No such device or address
Unmounting flash disk
Restarting system.
(0,0) Board BiB loaded into shared memory
Linux version 3.4.86-93 (henribak@rdbuild17.rd.tandberg.com) (gcc version 4.4.7 20131017 (Tilera 4.4.7-3) (crosstool-NG blah) ) #1 SMP PREEMPT Thu Feb 26 22:20:53 CET 2015
PERCPU: 2 64K pages/cpu @fffffff600000000 s82432 r8192 d40448
Policy zone: Normal
allocated 1036288 bytes of page_cgroup
please try 'cgroup_disable=memory' option if you don't want memory cgroups
Memory: 3697536k/4145152k available (9125k kernel code, 3903k data, 570k init, 0k highmem)
SLUB: Genslabs=15, HWalign=64, Order=0-3, MinObjects=0, CPUs=36, Nodes=4
NR_IRQS:32
Clock rate yields 2400.00 BogoMIPS (lpj=1200000)
Initializing cgroup subsys memory
ftrace: allocating 18375 entries in 5 pages
Brought up 36 CPUs
Advanced Linux Sound Architecture Driver Version 1.0.25.
IP route cache hash table entries: 32768 (order: 2, 262144 bytes)
TCP established hash table entries: 131072 (order: 5, 2097152 bytes)
TCP bind hash table entries: 65536 (order: 4, 1048576 bytes)
TCP: Hash tables configured (established 131072 bind 65536)
type=2000 audit(0.885:1): initialized
nfs4filelayout_init: NFSv4 File Layout Driver Registering...
fuse init (API version 7.18)
msgmni has been set to 7916
brd: module loaded
loop: module loaded
tilegx-ehci tilegx-ehci.0: irq 2, io mem 0xfffffff605460000
usb usb1: Manufacturer: Linux 3.4.86-93 ehci_hcd
tilegx-ehci tilegx-ehci.1: irq 3, io mem 0xfffffff605480000
usb usb2: Manufacturer: Linux 3.4.86-93 ehci_hcd
Initializing USB Mass Storage driver...
USB Mass Storage support registered.
usbcore: registered new interface driver libusual
usbserial: USB Serial Driver core
usbcore: registered new interface driver debug
ftdi_sio: v1.6.0:USB FTDI Serial Converters Driver
usbcore: registered new interface driver ir-usb
ir_usb: v0.5:USB IR Dongle driver
usbcore: registered new interface driver moschip7720
safe_serial: v0.1:USB Safe Encapsulated Serial
usbcore: registered new interface driver vivopay-serial
gpiochip_add: registered GPIOs 0 to 15 on device: tca9539
device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
EDAC MC: Ver: 2.1.0
Registering the dns_resolver key type
rtc-ds1307 0-0068: setting system clock to 2019-09-18 09:08:10 UTC (1568797690)
ALSA device list:
hrtimer: interrupt took 12173125 ns
Freeing unused kernel data: 320k freed
Freeing unused kernel text: 256k freed
 sda: sda1
Mounting flash disk
Switching root
systemd-fsck[770]: /dev/mapper/uifs: clean, 11/3584 files, 1605/14336 blocks
systemd-fsck[769]: /dev/mapper/config: clean, 11/7680 files, 2370/30720 blocks
After approx 1.5 hour got login prompt.
Then used commands:
xConfiguration Network 1 IPv4 Address: "192.168.1.128"
xConfiguration Network 1 IPv4 SubnetMask: "255.255.255.0"
xConfiguration NetworkServices SSH Mode: "On"
Got access via http and did restore config from backup file.
