Codian MCU 8510 alias number to change
t.gupta
Hi Folks
We have a Codian MCU 8510 and TMS.Both are connected to each other.There were some conference ids created in the MCU 8510 and whenever we schedule the conference from TMS uses these ids.I need to edit the conference id present in the MCU but couldnot.Could you please provide the steps that needs to be done in the MCU and also on the TMS to edit the E.164 alias number present in the screenshot.
Tarun
Patrick Sparkman
Hello Tarun -
You can specify the start number and step that TMS will use for the MCU in the extended setting.
Select your MCU, settings > extended settings.
