Conductor Essential Image
Siva chinap
Level 5
Level 5
Can u any body suggest where i can download the TP conductor essential image,we recently purchased TP server 310 we need to integerate with TP conductor ...as per the doccument there is no option key & release key required for TP conductor.
But with BE6K bundle we got TP conductor...so any body can give clear information on this
James Hodgson
The 'essential' image is exactly the same as the normal image just without a release key. If you already have the BE6k VM installed then no further effort is required.
If you wish to download the latest image/upgrade file, please look here: https://software.cisco.com/download/navigator.html?mdfid=283884153&i=rm
James
As James mentions, all versions of Conductor use the same OVA, what determines the exact version of Conductor you get is based on release and option keys.  Of course, if you don't install any release or option keys, you'll be running the free or Essentials version.
