ā03-15-2013 10:15 AM - edited ā03-18-2019 12:46 AM
I have tried to configure a CUCM 8.5 with TANDBERG 1700 MXP and I could not, if someone already did and help me with this issue either SIP or H323.
Thanks in advance
Solved! Go to Solution.
ā03-16-2013 12:07 PM
The mxp units can be registered to cucm as third party (basic) endpoints.
Please find the steps to register mxp.
Configure sip settings on mxp such as sip uri and proxy address.
1. Sip Mode: on
2. SIP Uri: DN@ipaddress of cucm eg: 9011@10.10.10.1
3. Server Discovery : manual
4. Server Address: ip address of cucm.
5. Server Type: cisco
6. Transport: let it be auto however incase that did not work, change to udp.
7. TLs: off
8: Sip authentication user name: user you have created on cucm eg 9011 or amlesh
9. Password: use same password configured while creating user 9011 or amlesh
CUCM config:
1. Select third party basic profile.
2. add mac address of mxp endpoint.
3. select proper sip profile, phone templates etc.
4. under digest user and owner user id select the same user eg: 9011 or amlesh
5. save the configuration and assign same DN that we used in sip uri settings on mxp.
6. Also associate mxp device to user using device association pane on cucm.
Please let me know if these work for you. I have tried this in my lab and that works.
Amlesh
ā03-17-2013 11:00 AM
I assume you have configured it however just to recheck, in CUCM for this particular third party profile, did you confiured the digest user and owner used id as "TANDBERG".
Also provide the xstatus sip from mxp CLI to further review the error.
Amlesh
1. Sip Mode: on
7. TLs: off
CUCM config:
Amlesh
ā03-17-2013 10:24 AM
Hi Amlesh,
Thanks for answer, I did the configuration in the MXP
CUCM IP is 10.60.0.70
User Name: TANDBERG
Password: TADBERG
and the configuration in the CUCM, I still have the registration rejected,
I dont know where is my mistake maybe you could find it !
Windsor
Amlesh
ā03-22-2013 11:08 AM
Hi.
Amlesh
Sorry for the delay in my response. You were rigth now is registered.
Thanks a lot
ā03-16-2013 03:03 PM
You can also register mxp in cucm as h323 device in cucm and it will also work.
Vivek
Sent from Cisco Technical Support Android App
ā03-17-2013 10:27 AM
Thanks for anwer,
could you bring me a configuration of a h.323 endpoint with the CUCM?
Windsor.
ā04-19-2017 09:02 AM
I am trying to register a 1700 MXP to CUCM 10.5.2 and am receiving a 500 Internal Server Error from the MXP.
I've tried it both with an unsecure and Digest Auth required profile without any luck.
I'm referencing this whitepaper for configuration but still no luck. Any help would be appreciated.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/7_1_2/ccmcfg/bccm-712-cm/b09sip3p.html
ā04-19-2017 09:43 AM
I just tried to register MXP 1700 (F9.3.4) to CUCM 10.5.2 as Third party basic device and it got registered.
I used exact same steps as provided in the post above.
Amlesh
ā04-19-2017 10:52 AM
ā04-19-2017 11:14 AM
Try to use these configuration:
++ Choose SIP profile as Standard SIP Profile
++ Device Security profile as Third-party SIP Device Basic - Standard SIP Non-Secure Profile or Disable Digest Authentication on current selected profile.
++ Choose Owner and then select owner userid.
Amlesh
ā04-19-2017 11:27 AM
I believe I found the issue. The 10.34.64.20 IP i used is the Publisher node in which we do not have the Call Manager service running as no devices register to it. Instead, I used a subscriber IP of 10.34.64.21 and that has allowed the unit to register successfully.
New issue is that calls made to and from video capable devices registerd to CUCM do not connect with Video, audio only.
When you place the call, make sure you select Dial Profile as SIP and not H.323.
Amlesh
ā04-19-2017 11:31 AM
Sorry - I edited my post as I caught that shortly after posting. Still have the above issue with no video either direction.
ā04-19-2017 11:34 AM
Make sure your region/location settings allow video calls.
Amlesh
