Configuring Cisco CMS recording and streaming
amsanosi
I have CMS1, CMS2, DB Cluster, I'm planing to add 2 CMS servers that both will be running recording and streaming
roles, what is correct commands to configure the XMPP on the server and the 2 XMPP clients
Note that callbridge is not running on the 2 new server do I still need to use command:
cms1>xmpp callbridge add CMS-ST-REC1
cms1>xmpp callbridge add CMS-ST-REC2
amsanosi
I have found the solution, Above command is used in XMPP Clustering only, and you must have Database cluster before deploying  XMPP Cluster.
The Recorder behaves like an Extensible Messaging and Presence Protocol (XMPP) client, so the XMPP server must be enabled on the server that hosts the Call Bridge.
follow below guide to configure the recorder
https://www.cisco.com/c/en/us/support/docs/conferencing/meeting-server/202722-Configure-Recorder-in-CMS-Acano-Call-Bri.html
thanks,
