Connect SX20 to Crestron controller
Avi7987
Can i connect my Cisco SX20 to a Crestron controller but not with RJ45?
My controller is not inside my network so i cant connect the SX20 to it in Ethernet...
Hope you have an answer for me...
Avi
Patrick Sparkman
You can connect to the SX20 using the following methods:
  • SSH
  • Telnet
  • HTTP/HTTPS
  • RS-232
Steps to connect using each method is outlined in the SX Series API Guides.
lukasburnes
You will need a USB-RS232 adapter dongle, attach it to a USB port on the codec and then you can utilize the serial control commands.
