Connect via Rs232
buiduongdk03216
Beginner
Beginner
Hi @Wayne DeNardi
First of all, We really care about your products and your products is very good
How do I connect to control Cisco Room kit plus Codec via Rs232 with Extron Processor as the Diagram bellow. Can you show details from connect diagram?
Thanks !!
I hope to hear from you soon !
Patrick McCarthy
For third party integrations, you can connect a USB (Type A) to serial (D-sub 9) adapter to support, for example a Crestron panel. Most USB to serial should work but Cisco recommends the UC232R-10 USB to RS232 (FTDI) adapter for the most tested and stable serial connection.
https://www.cisco.com/c/dam/en/us/td/docs/telepresence/endpoint/software/ce9/release-notes/ce-software-release-notes-ce9.pdf
