CUCM 12.5 and expressway 11.5 compatibility
ahmed
Hi all,
i am looking for document guide for deployment MRA using cucm 12.5 and expressway 11.5.
please help
ahmed
6 Replies 6
There is no expressway 11.5. is it the other way ?
Response Signature
Apologize, i mean X8.11.4
You can find all the material quite easily if you google Cisco MRA configuration + version
OR
Go to Cisco.com
Click on support
Product Support column -> All Products
Choose applicable option, Unified Communications in this case
Search applicable product, Expressway in this case
And you're in the product documentation.
java
if this helps, please rate
Upgrading from X8.11.4 > X12.5 or 12.6 should be pretty easy anyway - don't be fooled by the version numbers, X12.5 is the next version after X8.11
What reason is there that you don’t upgrade to the current version of Expressway?
Response Signature
