CPU load of CMS 1000 and CMS 2000 when working with full capacity
Tien Phuong
Hi all,
as we know, CMS1000 can host 48 fullHD calls and CMS2000 can host 350 fullHD calls (CMS2.4). But i don't know what is the percent of CPU load when it is working in full capacity. Anyone can provide document about this problem?
Jaime Valencia
I don't believe that is published anywhere.
java
if this helps, please rate
Thanks Jaime,
So if my customer have maximum 40 concurrent calls. If i want CMS does not work with  large than 80%CPU. i need sizing VM for CMS is: 40/0.8=50 calls?
CMS1K can easily handle 96 HD 720p30 video and 720p 5 content so I wouldn’t be worried on CPU here. Now if you push 1080p30 for both video and content then your capacity greatly reduces to approximately by 4, so you need to be looking at that. You can set minimum threshold etc to keep this in control
Thanks skilambi!
