Create Multiple Admin Users
jincto75
Sorry for the newbie question here.  I have a couple dozen Cisco video conference (Room Kit Plus) units that are managed by CUCM and using Expressway as the SIP proxy.  I want to create a new admin user with the same credentials on each Room Kit Plus.  Is there a way to do this from CUCM or do I have to create these manually on each device?
TechLvr
You may have found the answer to your question by now, but you do have to create the admin user manually on each device.
TechLvr
Hey thank you for your reply. I did find the answer and you are correct.
You can do this in bulk if you use a tool such as CE-Deploy.
Wayne
Please remember to mark helpful responses and to set your question as answered if appropriate.
