CTS 1100 with CTS Man.
bobby.jacob
I have an installation for a CTS 1100 and CTS 1300 soon, also i need to install CTS manager.
1)Can i know CTS Man 1.6 is compatable with MS Exhange 2010?
Is it mandatory to run Pre-Qual tool on the system.Or can we manually do the config on CTS Man during Post Install?
2)How long it may take for CTS Man. Installation and integration for MS Exchange.?
Tnx
Bobby
Rafal Szeremeta
Hi Bobby
For Exchange 2010 you need to have CTS MAN version 1.7 or higher. I would advice go for latest version 1.9 if possible
Installation shouldn't take longer than few hours, all depends on you environment, how many rooms you have, ect.
I strongly recommend to run Cisco PreQualification Assistant before running actual install.
Please check this documentation:
http://www.cisco.com/en/US/docs/telepresence/cts_manager/1_7/release/ctm_rn1_7.html
http://www.cisco.com/en/US/docs/telepresence/cts_manager/1_6/admin/ctm1_6adminguide.html
http://www.cisco.com/en/US/products/ps7074/tsd_products_support_series_home.html
Rafal
