CTS-MIC-CLNG-DNG pinout
eirik.skogoy
Do anyone have the pinout for the rj45 to minijack and phoneic to rj45 adapter. Named H and I in the Ceiling microphone installation guide
7 Replies 7
Patrick Sparkman
I don't think the pinout of those connectors are documented anywhere from what I can tell. What do you need the pinout for?
It is a system relocation where the adapers is missing, so trying to get it up and running as quickly as possible
Did you ever find out this information?
No sorry.
Thanks for the reply
This is the correct pin out configuration for a mic adapter to a VETCO TRRS adapter. If it helps.
For T568B cat cable, connecting a CTS-MIC-CLNG-G2 Cisco ceiling microphone to a codec, use blue (audio hot +), white blue (audio cold -), and white brown (ground) in left to right order if you need to get the sx80 running without the proper adapter.  The 4th connection will not be used as the ceiling mics don't have a mute button at the mic.  That connection is used for the tabletop mics with integrated mute button.
Thanks for posting this. I just helped one of our technicians connect these mics without the RJ45 adapter and this pinout worked perfectly. Thanks!
